Help with built in ftp
I need help with builtin ftp server i am trying to open the server shared file.But it says to login and it shows the user root and  ask me for password and when i type the password for root it dosent work for some reason it says uncorrect password even tho if i type that in the web to login to my server through web it works.
Try creating another user and log in with those credentials.  Not too many people still use FTP
Ok thx it worked I am using it for fast access to isos folder
  • 2 months later...
Still struggling to erase previously configured users in the built-in FTP. I’ve disabled the built-in FTP but, keep getting the errors under Fix Common Problems.
  • 2 months later...
Still having trouble with this. How do I remove the users and stop the Errors?
