January 17, 20206 yr Hey, guys mysetup Unraid 6.8.1 Ryzen 3700X MSI470Pro Plus 16GB 3200mhz RAM AMD card for unraid 970 GTX for Gaming in the VM I have some problem with the passthrough of my usb pci card. If i passthrough the usb card without a gpu all is working fine. But if i passthrough a pci usb card with a gpu (970GTX) i get blackscreeen. I add this one in the configuration "append pcie_acs_override=multifunction initrd=/bzroot,/bzroot-gui vfio-pci.ids=1106:3483" and its working fine without gpu passthrough. I checkt the error log but there is no error. Some can help me? For better understanding if i passthrough only the GPU the vm is working fine. If i passtrough only the pci usb the vm is working fine. But if i want to passthrough both gpu and usb the vm in uefi get blackscreen and in legacy boot is hang and loading but not working and one of the core of the cpu has 100% all the time where the vm is startet Edited January 17, 20206 yr by lgaltair
January 18, 20206 yr I have exactly the same problem. Also interested in a fix. (if possible). We have a discussion here regarding the Onboard Audio Controller, with the same behavior: https://forums.unraid.net/topic/81859-audio-controller-crashes-unraid/
