January 18, 20206 yr I'm having an issue with very slow read speeds from one of my drives. I don't believe the entire array is affected, it looks like just one drive. When I'm reading I get less than 5MB/s speed. It's painfully slow. Configuration is local server and local PC, two separate computers. I'm not trying to run a VM from Unraid, this is a separate computer. I have nothing else active right, no VMs or Dockers having disk activity. I've tried suggestions from this post and it didn't work: ethtool info: root@Bernard:/mnt/user/Games# ethtool bond0 Settings for bond0: Supported ports: [ ] Supported link modes: Not reported Supported pause frame use: No Supports auto-negotiation: No Supported FEC modes: Not reported Advertised link modes: Not reported Advertised pause frame use: No Advertised auto-negotiation: No Advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Port: Other PHYAD: 0 Transceiver: internal Auto-negotiation: off Link detected: yes EDIT: Apparently my 5MB/s speed was due to the terrible game I was trying to load. Normal speeds are around 60-70 which is still much slower than what they should be. bernard-diagnostics-20200117-2149.zip Edited January 18, 20206 yr by Blairwin
January 18, 20206 yr Community Expert If it's just from one drive the drive itself could be the problem, run a test with the diskspeed docker.
January 18, 20206 yr Author 14 hours ago, johnnie.black said: If it's just from one drive the drive itself could be the problem, run a test with the diskspeed docker. Apparently its the game. It has terrible speed from a network drive apparently as other games aren't having a problem. Diskspeed shows the disk having 100+MB/s speed so it's not a disk issue.
