Network speed is low
Hey @jonp You know I think it's good to understand at 100% Unraid and with this action I can use the same iso for the next VM/
@bonienl Thank you very much for your support, the problem is solved now !
Before that I think we need to use the virtio present on our Unraid, I don't know why 🤣
@jonp @bonienl Thank you again!
I don't understand after a reboot of Unraid and I already check all parameters and tried to uninstall the pilote and install one again the last pilote and the speed is low .
I just create a new Win10 VM and it works ...
Is it possible to clean correctly all pilotes on my old VM ?
I already to uninstall the pilote and reinstall this one but my problem is always present.
