February 24, 20206 yr Hi all, So Fix common problems found a hardware error and suggested using mcelog to find out what the issue is. I have attached my log files below. I am not sure if this is the error it is detecting, but in the log this is the error I keep seeing over and over: Feb 24 09:37:00 Unraid kernel: usb 1-3.2: new low-speed USB device number 116 using ehci-pci Feb 24 09:37:00 Unraid kernel: usb 1-3.2: device descriptor read/64, error -32 Feb 24 09:37:00 Unraid kernel: usb 1-3.2: device descriptor read/64, error -32 I am guessing it might be my USB stick going bad, but that seems strange as it is only 6 months old. All of this is running on a Dell R710 if that matters. Hopefully someone can give me some advice on this. Thanks! unraid-syslog-20200224-1705.zip
February 24, 20206 yr We seldom want just syslog. Go to Tools - Diagnostics and attach the complete diagnostics zip file to your NEXT post. Diagnostics includes syslog and many other useful things.
February 24, 20206 yr Author 5 hours ago, trurl said: We seldom want just syslog. Go to Tools - Diagnostics and attach the complete diagnostics zip file to your NEXT post. Diagnostics includes syslog and many other useful things. Ah ok, I thought I had included that. Here is the additional information. unraid-diagnostics-20200224-1617.zip
February 24, 20206 yr Author No, there doesn't seem to be any symptoms yet. But this just started a few days ago from what I can tell. Have not done a memtest. I am assuming you mean for the RAM? I have seen an error before on some of the ram sticks but it seemed to go away. I was planning on pulling the RAM and CPU's this weekend to upgrade them.
February 24, 20206 yr 3 minutes ago, TwoFive5 said: I have seen an error before on some of the ram sticks but it seemed to go away. Where did you see these errors if you didn't do a memtest? There should never be any memory errors. Everything goes through memory. Your data, the executable code, everything.
February 25, 20206 yr Author It was an error reported on the server's idrac. I moved some of the sticks around thinking the order I had them in was wrong. Sat Dec 21 2019 06:44:11 Persistent correctable memory error rate has increased for a memory device at location DIMM_A2. Thu Oct 24 2019 17:30:28 Persistent correctable memory error rate has increased for a memory device at location DIMM_A2. I am running a memtest now. Edited February 25, 20206 yr by TwoFive5 Added Information
February 25, 20206 yr 2 hours ago, TwoFive5 said: It was an error reported on the server's idrac. I moved some of the sticks around thinking the order I had them in was wrong. Sat Dec 21 2019 06:44:11 Persistent correctable memory error rate has increased for a memory device at location DIMM_A2. Thu Oct 24 2019 17:30:28 Persistent correctable memory error rate has increased for a memory device at location DIMM_A2. I am running a memtest now. Is this ECC memory? I didn't see that mentioned when I googled that Dell model.
February 25, 20206 yr 1 hour ago, TwoFive5 said: Yes it is ECC 12x2GB DDR3 Memtest won't get any errors since the memory is self-correcting.
February 25, 20206 yr Author 12 hours ago, trurl said: Memtest won't get any errors since the memory is self-correcting. That makes sense, I never knew that was the case with ECC ram.
