December 16, 201015 yr I'm trying to install the Samsung 2TB drive as disk 7 in my array. I currently am using the Adaptec 1430SA PCIE card to expand the SATA ports. I can see when my system boots, that it recognizes the new drive in port 1 on the card but when Unraid loads there's no notification of a new disk to assign and rebuild the array. Just comes up as normal as if the drive doesn't exist. Unraid Version 4.5.6 Samsung Drive: Spinpoint F4 HD204UI Not sure where to start to debug this. Any suggestions? Mark
December 16, 201015 yr Have you upgraded the firmware on the Samsung? http://lime-technology.com/forum/index.php?topic=9339.0 You MUST do so or data corruption is likely.
