March 14, 20206 yr I haven’t built a PC for over 15 years and would appreciate any input on this build. I have read a lot of forum posts and watched a ton of youtube videos and think I have a handle on most of what I need. If I’ve missed something or there is a better option I am completely open to changing the parts listed below. The case doesn’t need to look pretty because it’s going to live under my desk. It does, however, need it to be quiet and have room to grow my storage. My budget is somewhere around 3 thousand. Planned uses so far: Nextcloud Plex VM’s Unifi Controller Probably CCT security cams on a separate drive from the array. Processor Ryzen 9 3950X CPU Cooling Noctua DH-15 Mobo Asrock Rack X470D4U2-2T https://www.asrockrack.com/general/productdetail.asp?Model=X470D4U2-2T#Specifications Ram 4 Sticks of Kingston KSM26ED8/16ME M.2 - Cache and VM’s Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive MZ-V7E1T0BW HDD - For Storage Array 3 X Western Digital Gold 8 TB 3.5" 7200RPM Internal Hard Drive HBA - Not sure if this is the right one for my build LSI Broadcom SAS 9300-8i 8-port 12Gb/s SATA+SAS PCI-Express 3.0 Low Profile Host Bus Adapter HBA - Cables Graphics Card Radeon RX 5700 XT 8G - PCI Express x8 Power Supply - Right size for this build? be quiet! Dark Power Pro 11 650 W USB Kingston DataTraveler Micro 3.1 64GB Case - No idea - Just want it to be as quiet as possible Fractal Design Node 804 - $109.99 Or Probably overkill be quiet! Dark Base 700, BGW23, Midi Tower ATX, 2 Pre-Installed Fans
March 14, 20206 yr Your budget is a little different than mine . I would use a nvidia graphics card for transcoding in plex with the nvidia build. I don't think AMD is supported in docker. Assuming your going to use Docker for above apps.
March 15, 20206 yr Author Thanks for the input on the graphics card. I did some digging and think I found the issues you mentioned with Plex and AMD GPU transcoding and AMD GPU passthrough with Docker. Is there a graphics card you would recommend? I found the below that is similar in price and specs. EVGA GeForce RTX 2060 Super SC Ultra Gaming, 08G-P4-3067-KR, 8GB GDDR6
