Need help with port forwarding
Hello everyone!
I'm a new Unraid user and having some trouble making my setup accessible from outside my LAN.
I followed almost all videos from @SpaceInvaderOne to configure my server, and everything is working great, except for this problem...
So, my network setup is INTERNET => pfSense (VM on Unraid) => LAN (Desktop, Unraid Server, phones, etc).
The connection is pppoe (don't know if this information is relevant).
I have succesfully configured Wireguard and can use it to access my LAN (Remote Access to LAN) or even browse the internet (Remote Tunneled Access).
I installed and configured Letsencrypt, using my own domain domain.com), cloudflare and duckdns.
To test this setup, I'm using Sonarr (sonarr.domain.com).
In my LAN, it opens the Sonarr webui.
If I try to use my phone (4G), it doesn't open at all and after a while the browser give the error "err_connection_timed_out".
Well, I believe the problem isn't the port forwarding on pfsense, since it is working without problems on my LAN (using ports 180 and 1443).
Maybe my ISP is blocking port 80.
About this subject, I have a question.
SpaceiInvader says in this video that the method using DNS verification is useful if the ISP blocks port 80.
(This is a video that will show you how to create an ssl certificate using dns verification. This is useful if your isp blocks port 80 so you cant use http verification. Also using dns verification allows the creation of wildcard ssl certificates.)
So, if my ISP really blocks port 80, why this method isn't working?
I really apreciate all the help I can get, since I'm not able to solve this on my own....
I can provide screenshots, logs, whatever is needed.
Thanks in advance!
Ps. The same thing happened before I installed pfsense, when I was using a router from Asus (RT AC66U).
I already tried to do the process without my domain, using only duckdns, but the server never went to "ready" (it gave the "possible firewall problem).
Edit: My cloudflare is already configured to "only DNS" (disable the orange cloud).
Edited by luizmont
On 3/15/2020 at 8:30 AM, SpaceInvaderOne said:
@luizmontplease check here if port 443 is open and report back
https://www.yougetsignal.com/tools/open-ports/
Thank you very much for trying to help me!
Love your videos, they are very informative!
It says that it is not...
Here are my firewall rules, the rutorrent and wireguard ones work without any problems.
And my docker setup
And a diagram of my network
Edited by luizmont
@luizmont I may be over thinking this but I wouldn't post my external IP and various ports on any forum, it's unnecessary. Although it may be less of an issue than I think I'm going to bring @johnnie.black in, just in case the image should be removed.
Appreciate your concern!
My IP is dynamic and already changed, but if it's needed I can remove or edit the images....
So, I have confirmed that my ISP block ports 80 and 443 and as a home user, I can't open them.
What are my options to use reverse proxy with my unraid server?
I read something about "DNS challenge", but don't understand if this is the way to go (or how to implement it).
Thanks in advance!
  • 4 months later...
following, I have the same issue. Any update?
