April 6, 20206 yr Hi, I'm having overheating issues with my CPU and I installed the system temperature plugin. Noticed my CPU fan always runs at 800rpm but this is a Noctua Fan NH-L9i with 2500rpm My point is, the fan is not increasing the RPMs as the CPU gets hotter. Something I can do to help this? It wasn't happening before because I moved the computer to a spot where the AC doesn't reach as well. Sent from my Pixel 2 XL using Tapatalk
April 6, 20206 yr 3 hours ago, gacpac said: Something I can do to help this? You should check BIOS setting or try disable FAN control and check does FAN run in expect RPM.
May 3, 20206 yr Author You should check BIOS setting or try disable FAN control and check does FAN run in expect RPM.It was something in the Bios I figuredSent from my Pixel 2 XL using Tapatalk
