April 14, 20206 yr Hi! My computer has 2 NIC - one default motherboard and second intel. Intel doesnt work and I dont know why. Also I have problem with unifi docker. AP logs: Tue Apr 14 21:00:49 2020 user.err : mcad[19176]: ace_reporter.reporter_fail(): initial contact failed #1, url=http://172.17.0.2:8080/inform, rc=11 Tue Apr 14 21:01:05 2020 user.err : mcad[19176]: ace_reporter.reporter_fail(): Unknown[11] (http://172.17.0.2:8080/inform) after that I try to force "set-inform" with unraid IP and everything works. There is some problem with subnet that use Docker. Need help:) PS sorry for my english! tower-diagnostics-20200414-2205.zip
April 17, 20206 yr Author Put cable to Intel port and run diagnostics. Logs attached Also found new problem. Check "hide dot files" in SMB settings, after that shares became inaccessible. Try to stop shares and turn off "hide dot files" function, but shares stuck in stopping array. tower-diagnostics-20200417-1159.zip
April 17, 20206 yr Community Expert Still no link on either NIC, also you need to set the main NIC you want use as eth0 (then reboot)
April 17, 20206 yr Community Expert Router is not assigning an IP address, there are some users with recent release that need to set a static IP address, try that but if it doesn't work it's likely a LAN problem.
April 17, 20206 yr Author Put ip manually. Server works. Problem with unifi still exist. Also I have problem with wireguard. Try turn it on and connect from client at iphone. Nothing work. upnp turn onn, also try forward manually. Fresh diagnostics attached. thanks for the help! Fri Apr 17 21:24:01 2020 user.err : mcad[1038]: ace_reporter.reporter_fail(): Unknown[11] (http://172.17.0.2:8080/inform) Fri Apr 17 21:24:01 2020 user.err : mcad[1038]: ace_reporter.reporter_fail(): initial contact failed #1, url=http://172.17.0.2:8080/inform, rc=11 Fri Apr 17 21:24:26 2020 user.err : mcad[1038]: ace_reporter.reporter_fail(): Unknown[11] (http://172.17.0.2:8080/inform) Fri Apr 17 21:24:26 2020 user.err : mcad[1038]: ace_reporter.reporter_fail(): initial contact failed #2, url=http://172.17.0.2:8080/inform, rc=11 nas-fabius-diagnostics-20200417-2128.zip
April 17, 20206 yr Community Expert 10 minutes ago, evillena said: Problem with unifi still exist. Also I have problem with wireguard. Can't help with either of those, for Wireguard there are a couple of threads about it, in the Guides and Plugins forums, best to ask for help there.
