December 26, 201015 yr i got a sandisk cruzer micro 2gig usb stick when i plug it in i get two drives: - a cd station? f: U3 system - another g: station which i can store data on i tried to use syslinux.exe on g: but i get error: accessing physical drive: acces refused did not succesfully update the mbr, continuing.. whats wrong, and how come i get 2 drives from the usb stick instead of one i'm also not able to format f:
December 26, 201015 yr Sandisk drives come with software to do encryption. You need to do a google search for the U3 removal tool. Once you have it use it on the flash drive and you should be good after that. I have a Kingston DatTraveller drive that is similar to the U3 stuff. Though it is hardware based so removing the software would make the drive useless. It is great though as a work drive as it encrypts anything and if someone tries to get into it it deletes the contents on so many failed logins.
December 26, 201015 yr Author well, the u3 is deleted so only one disk now but i keep getting error typing: syslinux.exe -ma g: in dosprompt accessing physical drive: acces refused did not succesfully update the mbr, continuing.. if im doing it through run/start in windows 64 it just flashes but i cant read... i assume its the same error
