unmenu problem with flash filesystem rights
cannot get unmenu to install in ver5 beta 2. The flash drive indicates read-only permissions. The unmenu directory was created using windows on the flash drive and the install file place in the directory. Edited the go scripts and rebooted. Could not find the file. I then telneted into the server and cd to the unmenu director.ran  ls  command and the file is there. I ran the file based on these commands http://code.google.com/p/unraid-unmenu/. The read only files system message begin showing at this point.
unRAID will re-mount a file system as read-only if it detects corruption.
You might want to move the flash drive to a windows PC and run chkdisk on it.
(Right click on the flash drive in file-explorer and run the repair utility on it.)
Joe L.
Well I ran chkdsk, and now I have lost my plus license and my raid was downgraded to 3 drives.
Was able to recover the key from file*.chk files
