DelugeVPN using 100% of CPU power and cores
Im not fully sure but I think my DelugeVPN is loading my CPU's @ 100% 'I have 4 x 20 core Xeon CPU's so this should be really almost impossible ' I also have Deluge limited to about 8 CPU cores not all of them and it only does it sometimes, top CPU monitoring tells me sha256sum is the process that is creating the load but if I shut down Deluge it stops
any suggestions please
Edited by SundarNET
Please use the existing docker support thread, you can find by clicking on the link:
