Fix Common Problems showing Disk with Read Errors..SMART is fine?
So I have a Disk (Disk 2), which has had CRC Errors, and wasnt so concerned as put it down to a bad power connection in my previous PC, however it will not complete a SMART test (self aborts).
Because of this I have added some additional drives, and currently completing a "Unbalance" to move everything off Disk 2, and will Shrink the Array (as I dont have a replacement disk big enough to do a proper swap).
New smaller disks installed, and one of them (Disk 10) is flagging on Fix Common Problems as having Read Errors, however running extended smart tests etc, shows nothing at all.
Anything else I can do to validate this new drive?
media-diagnostics-20200608-0941.zip
Errors are being logged as actual disk errors, but that's not 100% reliable and the disk looks healthy and passed the extended SMART test, I would suggest replacing/swapping cables/slot with another disk and trying again.
