June 28, 20206 yr Need some assistance. I was replacing my cache drive and some how managed to break my usb flash drive. I just recently replaced my old usb with this new one. I guess I need to go out and buy a new one. I still have my old one though. What's the best way to go about fixing this? I honestly don't remember the process how to replace the usb stick. Edited June 28, 20206 yr by DigitalDivide
June 28, 20206 yr Need some assistance. I was replacing my cache drive and some how managed to break my usb flash drive. I just recently replaced my old usb with this new one. I guess I need to go out and buy a new one. I still have my old one though. What's the best way to go about fixing this? I honestly don't remember the process how to replace the usb stick. I guess you can replace your usb 1time per year. Envoyé de mon HD1913 en utilisant Tapatalk
June 28, 20206 yr Author I'm not sure what that means. If my usb was replaced say 3 months ago and now I damaged the new one, what does that mean?
June 28, 20206 yr Community Expert 3 minutes ago, DigitalDivide said: I'm not sure what that means. If my usb was replaced say 3 months ago and now I damaged the new one, what does that mean? You can get 1 automated replacement a year without having to contact Limetech. If for any reason you need a replacement in less than a year you need to contact Limetch support by email to explain why and giving them enough information to locate your current licence and the GUID of the replacement USB drive you want to use.
June 28, 20206 yr Author Is there a way to request a license from within the server? I thought that's how I did it last time. I'm pretty sure it was within the last 6months but not entirely sure.
June 28, 20206 yr Author I bought new usb flash, a sandisk 32mb Ultra. When I run the makeboot, it doesn't see the flash. Do I need to format it first with windows?
June 28, 20206 yr Author I managed to use the manual method to make the bootable flash. What files or folders do i need to copy from my old USB to the new one? Do I just copy the config folder over?
