July 2, 20206 yr Community Expert I deleted your docker run screenshot since it contained your plex token.
July 2, 20206 yr Author Just now, trurl said: I deleted your docker run screenshot since it contained your plex token. Thanks. I'll reset the password once we are done as well.
July 2, 20206 yr Community Expert 1 minute ago, mhn_10 said: Yes @trurl, these were the ones I had previously DelugeVPN Sonarr Radarr Bazarr Jackett Krusader OpenVPN LetsEncrypt DuckDNS Ombi Grafana/InfluxDB/Telegraf Tautulli HDDtemp For the above diagnostics, only Plex was running. If you reinstall one of those, does it work?
July 2, 20206 yr Author Just now, trurl said: If you reinstall one of those, does it work? Yes, all of them are starting. I tested Sonarr Grafana DelugeVPN Torrents are resuming as normal
July 2, 20206 yr Community Expert That indicates Unraid and its docker system is configured OK and working correctly, and I didn't see anything in diagnostics that would make me think otherwise. So your plex is the problem. You are using the "official" plex docker, and it doesn't have a support thread on this forum. Have you asked for help on the plex forum? You might try setting up another instance of plex and see if that one works. You would give it a different name and a different appdata path. You could even try a different plex docker. I personally use the linuxserver plex.
July 2, 20206 yr Author Hmm, Shall I try setting up a linuxserver-plex container. Once its setup, I then copy the old plex database to the new appdata location. Also, Is there anything that I must do in order to make sure I haven't been exposed from port 22. I'm worried since there were few ssh and ftp logs.
July 2, 20206 yr Community Expert The log I first saw didn't have a successful ssh login, or even many attempts. Not sure about the ftp, but I think the builtin ftp only gives access to /mnt if I remember correctly. How long were the ports open?
July 2, 20206 yr Author Just now, trurl said: The log I first saw didn't have a successful ssh login, or even many attempts. Not sure about the ftp, but I think the builtin ftp only gives access to /mnt if I remember correctly. How long were the ports open? 3-4 Days I would think. And the logs you saw was after a reboot. Since I rebooted when plex started crashing
July 2, 20206 yr Author 41 minutes ago, trurl said: So your plex is the problem. You are using the "official" plex docker, and it doesn't have a support thread on this forum. Have you asked for help on the plex forum? You might try setting up another instance of plex and see if that one works. You would give it a different name and a different appdata path. You could even try a different plex docker. I personally use the linuxserver plex. Looks like my plex database is corrupt. If I try copying just the database files from the old plex container to the new linuxserver container, the container fails to start.
July 2, 20206 yr Author Gonna recreate my database. Sigh. What is the general procedure next time, when I want to change my cache pool? Planning on getting a drive for making it RAID0 cache pool
July 2, 20206 yr Community Expert https://forums.unraid.net/topic/46802-faq-for-unraid-v6/?do=findComment&comment=480421
July 3, 20206 yr Author Thanks. I took a backup of the appdata using CA Backup/Restore and then I'm gonna follow this https://wiki.unraid.net/Replace_A_Cache_Drive to add the new drive. After that I'll do a balance with RAID0
