September 7, 20205 yr Hello I have an UPS Connected via a usb cable but the last power outage I had an unclean shut down. Not sure what to do but some suggestions on how to test this andor suggestions where to look on why this would be happening UNRAID Version: 6.8.3 DATE2020-09-07 12:19:32 -0400 HOSTNAMETowerVERSION3.14.14 (31 May 2016) slackware UPSNAMETowerCABLEUSB Cable DRIVERUSB UPS DriverUPSMODEStand Alone STARTTIME2020-09-07 12:12:55 -0400MODELUPS CP850AVRLCD
September 7, 20205 yr Look at the times before the system begins to shut down. If you're runnng a Windows VM, then quite likely it prevented the system from shutting down and you should install the virtio guest tools and set the VM to hibernate when the host shuts down.
