Mover Failing and CPU Max Load
A new issue started happening the past few days, mover will lock up the system and pin the cpu with max load. I show many sha256sum commands running taking up a lot of cpu, Only a reboot resolves the issues. I tried killing the mover in terminal but CPU is still pinned with sha256sum using most of it.
Setup:
Raid array with 2 parity
2 cache SATA SSD drives in raid 1
i7-4790
24gb ram
SS of top in terminal:
Any help identifying the cause would be helpful.
Edited by Spikerman
Looks like you have the file integrity plugin installed.
If you want additional advice, go to Tools - Diagnostics and attach the complete Diagnostics ZIP file to your NEXT post in this thread.
16 minutes ago, Spikerman said:
Yes i have the plugin installed, could that be the culprit? I
It is the cuprit.  Hashing all of your files is very cpu intensive
@Squid thanks, looks like that was it, i excluded my DL directory to see if that improves performance.
