September 11, 20205 yr Hi, I have set my unraid to a new configuration and started building parity, but i keep getting this error over and over with different sectors. I have updated my unraid version, and have been updating disks before this and converting to XFS. Sep 11 00:08:27 Tower kernel: sd 9:0:5:0: Power-on or device reset occurred Sep 11 00:08:31 Tower kernel: mpt2sas_cm0: log_info(0x31110d00): originator(PL), code(0x11), sub_code(0x0d00) Sep 11 00:08:31 Tower kernel: mpt2sas_cm0: log_info(0x31110d00): originator(PL), code(0x11), sub_code(0x0d00) Sep 11 00:08:31 Tower kernel: mpt2sas_cm0: log_info(0x31110d00): originator(PL), code(0x11), sub_code(0x0d00) Sep 11 00:08:31 Tower kernel: mpt2sas_cm0: log_info(0x31110d00): originator(PL), code(0x11), sub_code(0x0d00) Sep 11 00:08:31 Tower kernel: sd 9:0:0:0: [sdc] tag#995 UNKNOWN(0x2003) Result: hostbyte=0x0b driverbyte=0x00 Sep 11 00:08:31 Tower kernel: sd 9:0:0:0: [sdc] tag#995 CDB: opcode=0x88 88 00 00 00 00 03 a3 81 2a 00 00 00 00 08 00 00 Sep 11 00:08:31 Tower kernel: print_req_error: I/O error, dev sdc, sector 15628052992 here is my diagnostic file,thanks tower-diagnostics-20200911-0229.zip
September 11, 20205 yr Community Expert Diags are after rebooting, please post new ones after the error.
September 11, 20205 yr Community Expert Issues in multiple disks at the same time: Sep 11 02:54:30 Tower kernel: sd 9:0:7:0: Power-on or device reset occurred Sep 11 02:54:32 Tower kernel: sd 9:0:5:0: Power-on or device reset occurred Sep 11 02:54:35 Tower kernel: sd 9:0:6:0: Power-on or device reset occurred This suggest a power/cable issue, also good idea to update the LSI firmware since it's on a very old release: LSISAS2008: FWVersion(07.15.08.00) Current one is 20.00.07.00.
