September 12, 20205 yr I have had the "extended tests" running for almost 20 hours, which is longer than it takes me to do a full parity rebuild. I attached strace to the PID identified in "/tmp/fix.common.problems/extendedPID" and for more than 4 hours it's been looping continuously over the same 2856 directories under my Radarr: stat("/mnt/user/darr/radarr/MediaCover/XXXX", {st_mode=S_IFDIR|0755, st_size=158, ...}) = 0 Is this expected behaviour?
