Indentification Settings has no SSL https options? But my copy of unraid does not have these options in "identification setting"
In spaceinvaders tutorials he talks about enabling SSL for https.... but I can not see these options....
How do I enable HTPPS?
It is now under the Management Access page
is there instructions.... what is this "provision" thing? I tired clicking it with the setting on auto ... but got an error.. I searched the documents but the only mention of it is in the getting styarted guide and it dose not say anything about it.
I changed it to "ON".. lets the ports as default and firefix complains about the certificate.. and I click open anywya and it has a broken padlock icon in the address bar saying it is not secure...?
Is that actually working?
Edited by questionbot
Press the "?" icon at the top right for help within any GUI page
I'm sorry as that opens all these little tootips but I do not understand them.
Is the HTTPS working, even with that warning on the padlock in the startbar?
No.  You also have to provision and update the DNS record
Ok.. so how do you do that? is there a tutorial or something?
well I still can not work out how to do this... so i just changed it back to AUTO and stopped using HTTPS
* Go to Settings -> Management Access
* Set "Use SSL/TLS" to Auto and press Apply
* Scroll down and press "Provision"
-- If you get an error message, wait a few minutes and try again
-- If you continue to get an error message about DNS Rebinding, turn on help and read about how to disable DNS Rebinding Protection on your network
* Press OK at the dialog box that says your certificate has been provisioned
* You will be redirected to the new https url for your system
yeah, this is the bit I couldn't work out...
So you continue to get the DNS rebinding message after waiting a while?
Turn on help and scroll to the bottom of the page. There is a whole section that talks about potential solutions. Of course, there are many ways to setup a network and it is possible that you will need to do some research for your particular setup.
What router do you have and what DNS provider are you using?
