Speed and Disk problems
Hello
I recently decided to say goodbye to Synology and try something new with unRAID. So far everything has worked and i'm very satisfied with unRAID. However, i have the problem, that the system becomes noticeably slower when copying large amounts of data.
When I start the copying process, I start with about 105 MB/s, after a while the speed changes to about 50 MB/s. After a look in the forum, i changed in the Disk Settings to "reconstruct write" Mode. That only solved the problem for a short time. I found the following warnings and errors in the syslog:
Warnings
- Oct 1 02:19:46 myromdc01 kernel: ata21.00: failed command: READ FPDMA QUEUED
- Oct 1 02:19:46 myromdc01 kernel: ata21: hard resetting link
Errors
- Oct 1 02:18:55 myromdc01 kernel: ata21.00: exception Emask 0x0 SAct 0x3c00 SErr 0x0 action 0x6 frozen
- Oct 1 02:19:46 myromdc01 kernel: ata21.00: exception Emask 0x0 SAct 0x7f80000 SErr 0x0 action 0x6 frozen
As written in the forum i changed the SATA cables, but this had no effect.
Why do these error messages appear and what can i do about them?
myromdc01-syslog-20201001-1047.zip
Please post the complete diagnostics instead: Tools -> Diagnostics
The extra controller you have is a 2 port Asmedia controller with SATA port multipliers to give the 6 or 10 total ports, these are a known problem and will cause constant timeouts, you should replace it.
Ok, thanks for your Help. Is there a general problem with SATA port multipliers or only with this Asmedia controllers? I found this alternative with a Marvell controller, would that work? Or do you have a product that you can recommend?
Any controller with SATA port multipliers is not recommended, Marvell controllers are also not recommended, even without port multipliers, if 5 ports are enough you can get a JMB585 based controller, if you need more look for an LSI HBA.
