October 7, 20205 yr I've read through a number of posts, but I'm still a bit confused as to the best settings for CA Auto Turbo Write Mode. I have 1 cache, dual 8TB parity, 18 drives ranging from 4TB to 8TB. I'm struggling to determine optimal settings for the following two parameters Disks Allowed To Be Spun Down Before Invoking Turbo Mode Polling Time In Seconds Any help would be greatly appreciated!
October 7, 20205 yr Hi, It depends on what services you run (like dockers). Personally I have 14 disks incl. 2 parity. I like to invoke the turbo write manually. and let unRAID deal with the normal operation as it sees fit. But a suggestion without any knowledge about anything, would be 2/3 with a polling time of 30s but this is nothing more than a shot i the dark. /Alphahelix
October 7, 20205 yr Author 20 minutes ago, Alphahelix said: Hi, It depends on what services you run (like dockers). Personally I have 14 disks incl. 2 parity. I like to invoke the turbo write manually. and let unRAID deal with the normal operation as it sees fit. But a suggestion without any knowledge about anything, would be 2/3 with a polling time of 30s but this is nothing more than a shot i the dark. /Alphahelix binhex-emby binhex-radarr binhex-sabnzbdvpn binhex-rtorrentvpn binhex-sonarr binhex-nzbhydra2 binhex-jackett No virtualization etc. Edited October 7, 20205 yr by newoski
