Drive Errors need help
I log into my unraid box today and got 32 errors notification of one of my drives granted its a over 5 years old so not bad imho and I am going to replace the drive anyway however how bad is this drive?
Last SMART test result:
Completed without error
WDC_WD60EFRX-68MYMN1_WD-WX11D4448803-20201007-2309 disk2 (sde).txt
SMART looks OK to me. Probably something else is the cause of those errors. Bad connections are more common than bad drives.
Go to Tools - Diagnostics and attach the complete Diagnostics ZIP file to your NEXT post in this thread.
You should also run an extended SMART test, since there are recent UNC @ LBA errors.
It's logged as a disk problem, you should
ran test came back with Completed without error so what now?
Give it another chance but anymore errors recommend replacing.
gonna replace anyway 1 error is enough to replace a drive imho might be over kill but just like to learn what is wrong with it so i know for next time
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     50076         -
EDIT: from the logs before can you see what is wrong with the drive by the errors?
Edited by JoNBoYuK
I can only see that they are logged as "medium errors", aka bad sectors, but these can sometimes be intermittent.
