October 8, 20205 yr Good afternoon, This was the third time I had the same problem. The dockers and vms are not displayed. So I restart the server, nothing works anymore. Always in about 2 month intervals. I also changed the USB stick once, but it didn't work. Now I have created the stick again. (It worked with the 5th try) and it does not boot. It's really annoying, every few months the same problem but never the same solution. Every time I need hours for countless new installations until it works for whatever reason. Right now I'm back at the Unraid and I just don't want to boot. Does anybody know why this could be?
October 8, 20205 yr Community Expert Do you have a backup of flash, or are you starting from scratch every time? Be sure to boot from a USB2 port. Have you done memtest?
October 9, 20205 yr Author 20 hours ago, trurl said: Do you have a backup of flash, or are you starting from scratch every time? Be sure to boot from a USB2 port. Have you done memtest? Thanks for the answer. Since the USB stick can be used normally under Windows, I continued to use the Config folder. The RAM test shows no errors. Now my USB stick does not boot anymore, with another one it works (probably not the server). I wait until my new USB stick arrives to transfer the UNRAID license.
