Problem after I enabled SLL and removed it again?
Hi All
For a very long time I had problems using the Unraid certf. on a UNIFI router and I had to make these changes:
After that I only used my local IP address after that!
But by mistake I enabled SLL and I did remove it afterwards in the file ident.cfg file
# Generated settings:
NAME="PLEXZONE"
timeZone="Europe/Paris"
COMMENT="The Ultimate Media Server"
SECURITY="user"
WORKGROUP="WORKGROUP"
DOMAIN=""
DOMAIN_SHORT=""
hideDotFiles="no"
localMaster="yes"
enableFruit="no"
USE_NETBIOS="yes"
USE_WSD="yes"
WSD_OPT=""
USE_NTP="yes"
NTP_SERVER1="time1.google.com"
NTP_SERVER2="time2.google.com"
NTP_SERVER3="time3.google.com"
NTP_SERVER4="time4.google.com"
DOMAIN_LOGIN="Administrator"
DOMAIN_PASSWD=""
SYS_MODEL="Xeon E-2100G based 24-bay NAS system"
SYS_ARRAY_SLOTS="24"
SYS_CACHE_SLOTS="1"
USE_SSL="no"
PORT="80"
PORTSSL="443"
LOCAL_TLD="local"
BIND_MGT="no"
USE_TELNET="yes"
PORTTELNET="23"
USE_SSH="yes"
PORTSSH="22"
USE_UPNP="no"
START_PAGE="Main"
NAME="Tower"
SECURITY="user"
DOMAIN=""
DOMAIN_SHORT=""
hideDotFiles="no"
localMaster="yes"
enableFruit="no"
USE_NETBIOS="yes"
USE_WSD="yes"
WSD_OPT=""
USE_NTP="yes"
DOMAIN_PASSWD=""
SYS_CACHE_SLOTS="1"
USE_SSL="no"   <------- ok?
PORT="80"
PORTSSL="443"
LOCAL_TLD="local"
BIND_MGT="no"
USE_TELNET="yes"
PORTTELNET="23"
USE_SSH="yes"
PORTSSH="22"
USE_UPNP="no"
START_PAGE="Main"
I also removed any certificate in the folder: \flash\config\ssl
(I have a SWAG/Lets encrypt docker running using port 443 so I guess that would also interfere with the auto creation of a temp Unraid certificate?)
But how do I re-enable connection by IP to my server without rebooting the server?
No matter what I do now right now it will translate my local IP to a Servername.local that breaks my access to the server?
I cant remember what I need to do? Very long time ago, I removed this with the help of Limetech support because I couldnt connect to my server
My GO file is like this:
#!/bin/bash
# Start the Management Utility
/usr/local/sbin/emhttp &
#Setup drivers for iGPU hardware transcoding in Plex
modprobe i915
chown -R nobody:users /dev/dri
chmod -R 777 /dev/dri
And in my Ident menu I dont have any http/Sll options available
I have tried googling and reading the forum post but so far no luck
You've got to reboot
I was afraid you would say that.... 🤕
So login by prompt and reboot command....thanks
