Connection Refused Problem
Long story summarized: parity of cache drive failed and locked the machine on boot (mobo logo). Had to disconnect it to get Unraid to load. Cache drive was then in read only mode. After some troubleshooting I backed up the cache drive, formatted it, and moved the files back. Everything worked fine but under Docker it said I should rebuild docker image since it was corrupt. So I removed and rebuilt the docker image using previous installed apps. Now I can't get into any of my dockers via IP:port or subdomain. I get ERR_CONNECTION_REFUSED.
Any help resolving this issue? I'd like to get my dockers back up and running as soon as possible. Thanks.
UPDATE: When I re-created the docker image the custom network I created for proxy access was deleted so the dockers had 'none' set for connection network. Once I created the custom network and reset the dockers the problem was fixed.
Edited by thunderclap
