[SOLVED] first UNRAID installation - network does not work
I start by specifying that it is my first installation of UNRAID. I got all new hardware:
  • MOBO = AsRock Z490 Phantom Gaming 4
  • CPU = i3 10100
  • Memory = Corsair Vengeance LPX Memorie 16 GB
  • Flash Drive = SanDisk Ultra Fit Unità Flash, USB 3.1 to 16 GB, 130 MB/sec (Unraid installation)
  • Disk = WD Red 3TB x 3, WD White 10TB (parity), Crucial MX500 1TB (cache)
I was able to manually install UNRAID 6.8.3 on the flash drive because the "USB Creator" did not recognize it.
UNRAID boots me correctly and takes the configurations I have set but I can't get the network to work.
I tried to configure a static IP (and find the diagnostics attached) but it is not recognized by the router.
From the GUI I tried to set it in DHCP but it remains "Please wait ... configuring interface" and tries to take an IP (169.254.28.48/16) which is not part of my network.
Before proceeding with the array configuration and license purchase I would like to solve this problem.
I have no other OS installed as the PC is new.
What can I do to fix?
nas-diagnostics-20201109-1830.zip
Thank you so much.
With the beta version I solved everything.
  • JorgeB changed the title to [SOLVED] first UNRAID installation - network does not work
