November 12, 20205 yr So I have been on the fence about going to Unraid for a bit now. The past few days I decided to run a test system that I would be using as the Unraid Server. I installed a single drive and setup a single User share. Tried to rsync something over and would get ~20MB/s. That's just horrible speeds. I move the same file through the file browser and I get speeds of about 50-60 MB/s, Thats better but still now what it should be. I then tried sending the files just over SSH. I get ~95 MB/s. I have seen countless threads about Unraid having a smb problem. After spending two days testing and playing with this. I do believe there is an issue there. The machine I had planned on using is a Poweredge C2100. ( I know its an older machine). So I setup another machine Ryzen 7 1700 just to see if I get the same results. I did! I created a small video to show what I am talking about. Hopefully this can get fixed soon. I'd really like to switch my setup over to Unraid! 2020-11-12 13-52-51.mkv
November 12, 20205 yr Community Expert Go to Tools - Diagnostics and attach the complete Diagnostics ZIP file to your NEXT post in this thread.
November 12, 20205 yr Author A little more info. That ryzen machine is usually running Windows 10 so I can play some games. Well, I tested sending a file from it over SMB and would get ~113MB/s. I did multiple live boots of different distros. Ubuntu, Fedora, Manjaro with that machine also. All with the same results as my first post. . Slow over SMB fast over SSH.
