SopraNo3 : Rsync problem
Hello, so I am trying to RSYNC between 2 unraid servers. Everything starts off ok but then the destination server just dies and I need to restart and RSYNC again to pick up for where it got stuck. No idea why :(
Since your post only had a little in common with that old thread you put it on, I have split it into its own thread.
Are you saying the destination Unraid crashes completely? Does that server work well otherwise?
Hello, yes it does work well. It only crashes while rsyncing.
Post diagnostics from that server. Tools - Diagnostics, attach complete Diagnostics ZIP file to your NEXT post in this thread.
Hello, here are the diagnostics. Please note that it freezes after 1-2 hours of copying. Then I need to hard reset the Server and try again. It starts copying and after a while same thing again. Thank you for helping!
tower-diagnostics-20201129-0131.zip
