Vocatus Posted February 23, 2011 Share Posted February 23, 2011 Hi there, I'm using a robocopy backup script to backup my personal files to my backup folder on unRAID. The problem is that no matter how new the local copy (on the desktop) is, or how old, Robocopy always copies ALL data, not just changed data. I know this is an issue with unRAID because this doesn't happen when I backup to other mediums (flash drive / USB HD, etc). Desktop and unRAID are using NTP. From the unRAID GUI, it says the time is correct (8:48 am on 23Feb2011 at time of posting). HOWEVER, when I login to the command line and execute the clock command, this is what I get: root@SV01:~# clock Wed Feb 23 15:47:37 2011 -0.557609 seconds What's going on here?? Link to comment
ftp222 Posted February 23, 2011 Share Posted February 23, 2011 I believe you need to use the /FFT switch for robocopy. I had this issue initially as well with the Linux/Windows timestamps being slightly different. I also use the /COPYALL to preserve file and directory timestamps. Link to comment
Vocatus Posted February 23, 2011 Author Share Posted February 23, 2011 I believe you need to use the /FFT switch for robocopy. I had this issue initially as well with the Linux/Windows timestamps being slightly different. I also use the /COPYALL to preserve file and directory timestamps. Thanks ftp222. I just ran it with the /FTT switch, and it worked perfectly. This was the old line: robocopy %SOURCE% %DESTINATION% /COPY:DAT /MIR /W:%TIMEOUT% /XD %SKIP_DIRECTORY1% /R:%RETRY% /LOG:%LOGPATH% /TEE This is the new line: robocopy %SOURCE% %DESTINATION% /COPY:DAT /MIR /W:%TIMEOUT% /XD %SKIP_DIRECTORY1% /R:%RETRY% /LOG:%LOGPATH% /TEE /FTT While I've got a robocopy expert here, is there any way to prevent the full directory paths being displayed for EVERY file? For instance, instead of this: Copying... c:\games\doom\doom.exe c:\games\doom\doom.cfg c:\games\doom\doom.bat can I set it to look like this?: Copying... c:\games\doom\... doom.exe doom.cfg doom.bat ? Link to comment
ftp222 Posted February 23, 2011 Share Posted February 23, 2011 can I set it to look like this?: Copying... c:\games\doom\... doom.exe doom.cfg doom.bat ? I don't know of a way to output the format like that and I'm not sure it is possible. I know you can use a /V to show skipped files, but I still think it displays the full path for every file, which I know can get unreadable for deeper folders. I'm not on my box right now, but you could try the /ETA switch, but I doubt that cuts off the path's. Beyond that I think you're out of luck. Link to comment
