October 24, 20215 yr Hi, I'm running an Unraid server which I use for deep learning. I use the Nvidia-Driver plugin to pass my GPUs to a docker container which then trains my models. Since my GPUs sometimes run hotter than I would like I'm looking for a way to control the GPU fan speeds. So far I have not been able to get nvidia-settings working in the docker container or on Unraid itself. Is it possible to manually control the GPU fan speeds on Unraid? In case it is possible, would it be better to control it from the docker container or from Unraid directly? Thanks in advance, Michael
