peachyojon Posted April 28, 2022 Share Posted April 28, 2022 (edited) I should preface this by saying all was going well until I changed the structure (cache pools/size etc) of my array, moved some files with unBalancer, and then all hell broke loose - but only for Postgresql! Also I don't have backups and I've accepted my loss, which isn't too bad as while the db was important it only had recent data on it. I am sourcing a proper backup solution and won't be changing the array again, but I'm new to all this and it has been fun. My setup includes a HP Dl380P G8 running 6.10.0-rc4. I've got 50+ containers running something or other, many with a mix of NFS share mounts or standard binds to /mnt/user/data or /mnt/user/appdata. I also had issues with my NFS shares where they would drop off after a single read/write and I would have to restart the container to get it back. After reading the forums to fix this I have to: disable hard links, remove cache, or use CIFS. I chose to disable hard links as I assumed any were viable options. Note: I started using NFS shares as my *arr stack, jellyfin, nzbd, and qbit/deluge were having permission issues even though they're mostly lsio containers running on 1000:1000 (iirc). Trying to have '/mnt/user/data/shows/??' available to multiple containers was the issue I think. Advice here welcome too. This fixed my NFS issue but lead me to the Postgres issue I think - even though Postgres is not using an NFS share, it is bind mounted to /mnt/user/appdata/postgres. My current issue is once the array was reconfigured (1 parity, 6 disks) and a new cache drive, I had mostly everything working with no problems, trying to start Postgresql official docker running 14.2, I started to get an error: 2022-04-28 18:48:12.879 ACST [29] LOG: could not link file "pg_wal/xlogtemp.29" to "pg_wal/000000010000000000000001": Function not implemented 2022-04-28 18:48:12.882 ACST [29] FATAL: could not open file "pg_wal/000000010000000000000001": No such file or directory Stackoverflow posts tell me my db is f*****. Fair enough, they recommended to simply reinstall the Postgres instance and copy the /data directory back. I did this but the issue persisted. I thought maybe disabling the hardlinks caused it (reference 'could not link file') but the kicker is I had it working last night with a fresh DB (literally dozens of re installs and trying nothing new and it worked one time) but now it's not working. As noted, while the new container worked, I had issues simply creating a new container having the same issue as above, even though the files should not exists. Questions: - Could disabling the hard link support in Global Share Settings be causing this issue?, and - Why would the link issue persist even when I completely reinstall the container? I believe I know my long-term fix would be to: - Properly establish bind mounts for all containers, or - Migrate any share to CIFS/SMB Please let me know which log files you need. Edited April 28, 2022 by peachyojon Quote Link to comment
peachyojon Posted April 30, 2022 Author Share Posted April 30, 2022 Enabled hard links and migrated to CIFS to fix isues. Quote Link to comment
