Unraid 6.9.2 Restore settings after power failure corrupted USB
Hi all,
About six months ago I was out of town and we had multiple power outages while I was away.  Unfortunately, my UPS wasn't configured correctly and my unRAID server went down and came back up multiple times with the outages.
When I got home I ran a parity check and all of my data was fine but I noticed that a bunch of my settings, like the server name and FTP off/on, had changed or reverted back to defaults and I found a ton of fsck files on my USB drive--presumably because some process tried to fix a damaged filesystem.
I restored my VMs from my backup but when I went to restore my USB drive/unRAID setting I realized that I had made a serious mistake.  The CA plugin I had been using for USB backup was just doing a daily rsync rather than a versioned backup!  It had already been more than a day by the time I got back so my backup had already been overwritten.
Initially, I thought, no problem, I documented my setup, Ill just follow my own instructions.  But, as is often the case, my docimentation isn't perfect, and after I finished my initial setup I didn't document every little tweak.  All that to say, I don't have a perfect record I can recreate my unRAID settings from.
After all of this happened, I ended up just shutting down my server.  I didn't have time to deal with it and I didn't know what I even had to do to fix things or if I had a viable and secure configuration.  But now I have some time again and I want my server back (and I want my data back).  This time around, I started by copying everything from the USB drive to my workstation and then diffing against the baseline install zip file from the version of unRAID I was using.  I figured I would be able to at least get a good indication of the changes I had made.  However, once I started going through the diff I found changes all over the place and it looks like some config files may have had defaults written to them which overwrote my settings (not confirmed, I just see a lot of settings that don't match what I remember).
Any ideas how to get everything back to my settings?
Best,
-- Jokes
Edited by JokesOnYou77
  • JokesOnYou77 changed the title to Unraid 6.9.2 Restore settings after power failure corrupted USB
