Decrease idle power for Ryzen 5 1500X
Hello everyone,
I have read tons of power consumption threads but now I am more confused than before.
The requirements:
  • Network storage for documents, pictures movies and so on
  • Plex
  • Maybe some VM and docker play, maybe Home Assistant (currently on RaspiPi 3B+)
  • Low idle power consumption
The beginning:
I bought a cheap Dell Optiplex 7010 SFF with an i5-3570 and threw 2 Seagate Ironwolf 6TB (ST6000VN001) into the case and went with that for a while. Power consumption in idle was around 34W and I did not have a lot of troubles with it.
The problem was the Dell mainboard which did not let you configure a whole lot and the temps in the small case.
My "spare" windows PC was not used anymore I wanted to upgrade the server. Maybe newer components meant better power and efficiency.
New build:
  • Mainboard:   Asus Prime B350-Plus (BIOS Version 6203)
  • CPU:            AMD Ryzen 5 1500X
  • Cooler:         Noctua NH-D15 SE
  • RAM:            G.Skill Aegies DDR4-3000 16GB (2x8GB)
  • GPU:            XFX Radeon RX 590 Fatboy
  • SSD:            Kingston KC2500 500GB M.2 NVME
  • HDD:            Seagate Ironwolf 6TB (2X)
  • Case:           BeQuiet Pure Base 600
  • PSU:            BeQuiert Pure Power BQT L7 530W (Will be swapped with a BeQuiet Pure Power 11)
  • Fans Front:  Noctua NF-P12 (2x)
  • Fans Back:   BeQuiet Pure Wings 2
I managed to get the idle consumption to 38W but I would like to get this even lower. In Idle mode there is only Plex running in Docker and the only spinning fans are the 2 CPU Cooler Fans. The cooler is a massive overkill anyway but I have not managed to get them disabled at low temps yet.
Do you think it is possible to get the consumption even lower or do I need to switch to team blue for that?
The first generation Ryzen CPUs have a bug which prevents them from going into the low power C-States in Linux, causing system freezes.  So you won't find much power savings there.
What are you using the RX 590 for?  That is probably a good part of your power consumption.
Good morning,
so it would be better to switch to a later gen Ryzen?
Since I scrapped the "Gaming" setup, I thought I might have this as a VM in unraid.
In addition to this, the CPU does not have an internal GPU, sadly.
So the solution was: Get different Hardware.
I switched to this
  • Asus H97-Plus
  • Intel Core i5 4590T
  • BeQuiet Pure Power 11
  • Noctua NH-D15 SE without fans
With all the available power saving options in the bios switched to enable I now managed to drop to 24W with HomeAssistant VM running
