Help configuring network interfaces for NUT
Hi
Fairly new to unraid and I'm having a bit of trouble configuring NUT.
Unraid is the NUT master, and I've connected 2 servers via ethernet, to act as NUT slaves.
The Unraid server has 3 interfaces (eth0, eth1 & eth2)
Eth0 is my main interface, connected to the internet and has a 192.168 IP address.
I have set self assigned IP's to the 2 other interfaces (169.254.9.200 & 169.254.9.210) and connected each interface directly to each server.
From 1 server, I am able to connect to the unraid NUT server and can ping 169.254.9.200 fine. The 2nd server does not connect to NUT and cannot ping 169.254.9.210.
However, I have noticed that I can ping both .200 and .210 from the first server, but cant ping either from the 2nd.
Both servers have 2 ethernet interfaces, 1 for internet access, and 1 specifically for NUT. I've set self assigned IP addresses on the secondary interfaces for both servers (169.265.9.175 & 169.254.9.180)
Can anyone help with what is going on here please? It appears that Server 1 can ping the IP of eth1 and eth2, whereas Server 2 cannot ping either.
Cheers!
Thanks for your advice guys. I’ve managed to figure out what was going on.
I’ve bridged eth1 and eth2, but this wasn’t the issue.
My VPN on server 2 was blocking connection to the Unraid server. Doh!
I’ve created a split tunnel to allow the traffic.
thanks again!
