running out of memory....user shares a problem?
hey guys...
I have 1 gig of memory in my system and when i do a fresh reboot I have about 700 megs free.  After about 2 days of use, the free memory drops down to about 12 megs.  Is this a problem?
I have several user shares that I write to through my network.  I only write to user shares and never to the disk shares, could this be a problem?
I can post the syslog, but I don't really see anything important in there, and the file is not 800mb:)
Thanks,
Munky
Normally that is not a problem. Linux will use all available memory for caching files. This is normal.
If your syslog is taking up all of your memory then you have a problem..  >:(
Sounds normal... the rest is in disk buffer cache and will be re-used as needed.
(Good that your syslog is not 800Meg  ;))
On my server I have 512Meg of ram, and most of it is in the disk buffers.  Only "6972k" is free at the moment.
Mem:    514016k total,  507044k used,    6972k free,  329380k buffers
root@Tower:/var/log# free -m
                  total       used       free     shared    buffers     cached
Mem:          1001        971         29          0          0        929
-/+ buffers/cache:         41        959
... is this ok?
