Need help, with bad drive issue...
I decided to replace one of the drives in my array with a bigger one I had lying around... simple right?
1. stop array
2. shutdown array
3. unplug the 750G drive
4. plug in the new 1TB drive
5. turn on machine
6. check "the box" and start the array
Here's where the problem is.. The 1TB drive seems to have errors.. It tries to rebuild the drive but can't complete because of errors.. after about 2 mins it stops completely.. OK I decide I'm going to shut down the array and put the old one back..
NOOOPE
now the array says "Replacment disk is too small." and i am stuck.. Is there any way to get it back to the way it was or am I now forced to buy a larger drive and do a rebuild?
Many thanks to Tom for giving us this procedure!  It has been used a lot.  I know in my first months of unRAID, fighting with a bad motherboard, how I longed for a procedure like this.  I kept having to rebuild either the parity drive or a data drive.
