April 18, 200917 yr Hi to all When I transfert files from my share to say.. my computer's HDD on a 100 mbit network, I only got about 9.8 Mb/s of speed. Isnt it slow ? A 114 Mb file take 11-12 seconds to transfert... Should I expect at least 25 - 30 Mb/s ? All is linked by a D-link 624 router What can I do ? My go file looks like this: -------------------------------------------------------------------------- #!/bin/bash # Start the Management Utility /usr/local/sbin/emhttp & echo nameserver 192.168.0.1 >/etc/resolv.conf echo 192.168.0.101 fileserver >> /etc/hosts sleep 30 for i in /dev/md* do echo Setting $i blockdev --setra 2048 $i blockdev --getra $i done -------------------------------------------------------------------------- I also have attached my syslog... HDParms gives me that: -------------------------------------------------------------------------- root@fileserver:~# hdparm -tT /dev/sda /dev/sda: Timing cached reads: 1816 MB in 2.00 seconds = 907.88 MB/sec Timing buffered disk reads: 244 MB in 3.02 seconds = 80.70 MB/sec root@fileserver:~# hdparm -tT /dev/sdb /dev/sdb: Timing cached reads: 1798 MB in 2.00 seconds = 898.99 MB/sec Timing buffered disk reads: 224 MB in 3.01 seconds = 74.36 MB/sec root@fileserver:~# hdparm -tT /dev/sdc /dev/sdc: Timing cached reads: 1832 MB in 2.00 seconds = 916.10 MB/sec Timing buffered disk reads: 238 MB in 3.02 seconds = 78.70 MB/sec root@fileserver:~# hdparm -tT /dev/sdd /dev/sdd: Timing cached reads: 1708 MB in 2.00 seconds = 853.73 MB/sec Timing buffered disk reads: 52 MB in 3.02 seconds = 17.19 MB/sec -------------------------------------------------------------------------- Please can someone help me Thank you Ryno
April 19, 200917 yr I think you meant 9.8 MB/s, not 9.8 Mb/s (MegaByte vs Megabit). (9.8 Mb/s would be roughly equivalent to 1MB/s.) For a 100Mb/s network, your numbers (and your syslog) look good. The practical max for a 100Mbps network is around 10MB/s. Since you have a gigabit card in there, you just need to add a cheap gigabit switch to your current network to gain the 25MB/s speeds (and of course gigabit cards in the desktop machines). Add this D-Link switch, connect your server and gigabit desktops to it, plus a cable to the 624, and without any config necessary, you'll have gigabit speeds between your workstations and to the unRAID server, with nothing changed on the D-Link 624 and its support for the Internet and any wireless connections.
