dmcURAID Posted June 2, 2016 Share Posted June 2, 2016 I have an ASRock E3C224-4L motherboard and in general unRAID (6.2.0-beta21) works well. One issue I have never resolved, however, is that a USB device connected to ANY internal and external USB connector only shows up on Bus 003. Here's the output from lsusb (I added some dashes to separate each Bus): root@unRaid:~# lsusb Bus 002 Device 002: ID 8087:8000 Intel Corp. Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ---------------- Bus 001 Device 002: ID 8087:8008 Intel Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub ----------------- Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub ----------------- Bus 003 Device 005: ID 051d:0002 American Power Conversion Uninterruptible Power Supply Bus 003 Device 003: ID 0763:2012 Midiman M-Audio Fast Track Pro Bus 003 Device 010: ID 046d:c07e Logitech, Inc. Bus 003 Device 009: ID 1b1c:1b08 Corsair Bus 003 Device 008: ID 2109:2812 VIA Labs, Inc. VL812 Hub Bus 003 Device 007: ID 2109:2812 VIA Labs, Inc. VL812 Hub Bus 003 Device 006: ID 05dc:a81d Lexar Media, Inc. Bus 003 Device 004: ID 046b:ff10 American Megatrends, Inc. Virtual Keyboard and Mouse Bus 003 Device 002: ID 046b:ff01 American Megatrends, Inc. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub In searching the ASRock Rack site, I noticed a significantly updated BIOS, version 3.20 and it is nearly two years newer than second most recent BIOS, the 2.10 version I'm using now. I flashed the BIOS and unRAID booted fine. In fact, lsusb showed that the motherboard type A connector (the one with the unRAID boot stick) was now on Bus 001. But, alas, Bus 002 and Bus 004 still do not appear to be connected. More importantly, I cannot get the new BIOS to recognize either of the GTX750ti video cards installed in the 16x PCIe slots. That is, they do not appear when the lspci command is issued. So, of course that broke my VM's with GPU pass-through. Ironically, the ASRock Rack website lists, "Improved PCIe device support" as a feature of the new BIOS. I flashed back to the 2.10 BIOS and the video cards were recognized once again and the VM's worked properly. So, after that long-winded explanation, if anyone has unlocked the mystery of this motherboard's USB support or has any suggestions about the video cards not being recognized under the new BIOS, I would be most grateful. I'm sooooo close to getting a perfect unRAID setup, but I just can't seem to articulate the search terms for the USB problem. Sincere thanks to everyone on the forum. It really is a fantastic resource and I've overcome most of my setup/issues here. Link to comment
dmcURAID Posted June 2, 2016 Author Share Posted June 2, 2016 I sent ASRock an email about the updated BIOS issues I was having (v 3.20). I just happened to check their website again and the v 3.20 BIOS has been removed from the available downloads. I'm hopeful that means they are working on it. Link to comment
