June 12, 20188 yr Hello all. I have a Dell R510 with 4 ports that i'm having some issues understanding the best configuration for. About 5 months ago I was able to setup a gigabit connection via cards between the R510 and a R610 server. I was using the R510 only for storage. I have since started playing around with all the features of Unraid and wow, I was missing a lot! So since I messed around with the network settings I'm getting drops and now the "Docker webui" shortcuts take me to About:Blank. I am not sure what images you would need, so i'll include a few here. https://imgur.com/a/i3oFUpe https://imgur.com/a/QtqMjKN https://imgur.com/a/iacfkux https://imgur.com/a/wpU5BkF I dont need a real fancy setup, I would just like to be able to access the "webui" with the shortcut and not have anymore errors if possible. I would also like to utilize the 4 ports on the NIC. Question here: Should all 4 ports function at the same time, or are they redundant? https://imgur.com/a/85Dsevw Thanks in advance!! Loving this product EDIT: I guess a better questions might be is it possible to reset the network settings to default without totally starting over? Edited June 12, 20188 yr by grizzle33
June 14, 20188 yr Author It keeps getting worse... https://imgur.com/a/NRad6Wf The drops. Lots of drops and I can't figure out why
