Mansie Posted August 16, 2018 Share Posted August 16, 2018 Hi, I'm new to Unraid, i'm having issues with creating a VM with an external USB studio mixer connected to it. The mixer connects through 1 USB connector and shows up as 6 different USB devices in Windows or Unraid. It gets recognized correctly but i can't boot the VM with 1 or more of the codecs connected, when booting the VM i get an error regarding duplicate devices. I found a possible solution on the internet, but i can't get it to work. Possible solution: https://lime-technology.com/forums/topic/39966-vm-usb-passthrough-multiple-devices-with-the-same-vendorproduct/ I'm trying to edit the XML config, so it doesn't use the vendor id's anymore, i tried every possible combination of busses and devices which made sense but i can't get it to recognize the codecs. The other 2 USB devices work flawlessly. Connected Unraid Devices: Bus 003 Device 006: ID 03eb:2402 Atmel Corp. Bus 003 Device 007: ID 08bb:29c0 Texas Instruments PCM2900C Audio CODEC Bus 003 Device 008: ID 08bb:29c0 Texas Instruments PCM2900C Audio CODEC Bus 003 Device 009: ID 08bb:29c0 Texas Instruments PCM2900C Audio CODEC Bus 003 Device 010: ID 08bb:29c0 Texas Instruments PCM2900C Audio CODEC Bus 003 Device 011: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC Can someone help me too figure this out. I can't simply passthrough an USB host adapter because i want to split the 4 codes over 2 VM's in the future. Apoligies for the bad English, it isn't my native language. Regards! Link to comment
