Down & upload speed problems with cache ssd's
Hey Guys,
I've got a problem with my Unraid Server.
I just installed a CAT6 S/FTP patch cable (30 meters).
The speed during an upload to my Cache Pool (2x Samsung 850 Pro SSD's) is around 340MB/s.
If I want to download the same file from the exact same folder, it only runs with around 120MB/s.
The option "use cache disk" is set to "yes". I already tried "only" without any difference.
All together it seems to be too slow. And i honestly don't know why.
The partition format on both cache drives is "MBR: 4K-aligned" and they are set to a RAID 0.
The Network connection under unraid says: "10000 Mb/s, full duplex, mtu 1500"
Is there something i am missing?
One SSD should be able to get up to 520MB/s...
It would be great if anyone of you guys can help me out. :)
Cheerz,
Chris
