September 2, 20197 yr I have both acs overides enabled and my onboard audio is in its own iommu group. It shows up in windows 10 vm but I get error code 10 device can't start. Edited September 5, 20197 yr by jpowell8672
September 3, 20197 yr Author Solved: I figured it out. Just in case any one else has this problem. I had to keep my nvidia audio from my graphics card passthrough as first audio device and add onboard audio as the second audio device for it to work.
