jezzaf14 Posted May 2, 2020 Share Posted May 2, 2020 Hi not sure if im posting in the right place, but here goes. i have a plex docker installed and running however when i try scan my usb tv card i get the following errors. May 02, 2020 16:20:31.187 [0x1468e1ce2700] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 816500,,,7 May 02, 2020 16:20:31.252 [0x1468e1ae1700] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1 if i install TVH plugin it works fine. so im not sure if its a permissions problem, a plex problem (the tuner works fine with plex in windows) or a docker problem. any help would be great im running unraid 6.8.2 thanks Quote Link to comment
