September 12, 200719 yr I'm trying to buy the pro version, but I don't have a Flash GUID. Can you help me, so I can spend some money? Thanks, James
September 12, 200719 yr I'm trying to buy the pro version, but I don't have a Flash GUID. Can you help me, so I can spend some money? Thanks, James Install the free version and it will tell you the ID. You can also cobble it together with windows utilities, but the Unraid method is far safer. If you really don't have an ID (all zeroes), then you need a new USB key that has one. Bill
