November 1, 20206 yr Hello, Having Unraid installed on my DIY NAS for 4 months, I faced very little problem but here I admit that I am a bit stuck. I just updated the "haugene / transmission-openvpn" docker and now it no longer wants this to connect to my NordVPN account. I reluctantly remove my container and reinstall it! but still the mm thing. I spent 2 days doing the forum and I went to see the dev side but I didn't really understand everything! Anyone have any info on the subject or manip? Thank you in advance for your kindness :) Provider NORDVPN has a custom startup script, executing it Downloading user specified config. NORDVPN_PROTOCOL is set to: UDP 2020-10-31 11:09:17 Checking curl installation 2020-10-31 11:09:17 Removing existing configs 2020-10-31 11:09:17 Selecting the best server... 2020-10-31 11:09:17 Searching for group: legacy_p2p 2020-10-31 11:09:17 Searching for technology: openvpn_udp 2020-10-31 11:09:17 Best server : fr617.nordvpn.com 2020-10-31 11:09:17 Downloading config: default.ovpn 2020-10-31 11:09:17 Downloading from: https://downloads.nordcdn.com/configs/files/ovpn_udp/servers/fr617.nordvpn.com.udp.ovpn 2020-10-31 11:09:17 Using OpenVPN CONFIG :: norway 2020-10-31 11:09:17 Downloading config: norway.ovpn 2020-10-31 11:09:17 Downloading from: https://downloads.nordcdn.com/configs/files/ovpn_udp/servers/norway.udp.ovpn 2020-10-31 11:09:17 Checking line endings 2020-10-31 11:09:17 Updating configs for docker-transmission-openvpn Supplied config Norway.ovpn could not be found. mknod: /dev/net/tun: File exists Using OpenVPN provider: NORDVPN Provider NORDVPN has a custom startup script, executing it Downloading user specified config. NORDVPN_PROTOCOL is set to: UDP 2020-10-31 11:09:33 Checking curl installation 2020-10-31 11:09:33 Removing existing configs 2020-10-31 11:09:33 Selecting the best server... 2020-10-31 11:09:33 Searching for group: legacy_p2p 2020-10-31 11:09:33 Searching for technology: openvpn_udp 2020-10-31 11:09:33 Searching for group: legacy_p2p 2020-10-31 11:09:33 Searching for technology: openvpn_udp 2020-10-31 11:09:33 Best server : fr617.nordvpn.com 2020-10-31 11:09:33 Downloading config: default.ovpn 2020-10-31 11:09:33 Downloading from: https://downloads.nordcdn.com/configs/files/ovpn_udp/servers/fr617.nordvpn.com.udp.ovpn 2020-10-31 11:09:33 Using OpenVPN CONFIG :: norway 2020-10-31 11:09:33 Downloading config: norway.ovpn 2020-10-31 11:09:33 Downloading from: https://downloads.nordcdn.com/configs/files/ovpn_udp/servers/norway.udp.ovpn 2020-10-31 11:09:33 Checking line endings 2020-10-31 11:09:33 Updating configs for docker-transmission-openvpn Supplied config Norway.ovpn could not be found.
January 6, 20215 yr The problem seems to be that nordvpn changed the urls. Accessing https://downloads.nordcdn.com/configs/files/ovpn_udp/servers/fr617.nordvpn.com.udp.ovp results in a 404 the new url schema is something like that: https://downloads.nordcdn.com/configs/files/ovpn_legacy/servers/fr533.nordvpn.com.udp1194.ovpn This file would probably need to be updated, but I don't really know how: https://github.com/haugene/docker-transmission-openvpn/blob/master/openvpn/nordvpn/updateConfigs.sh
