fresh 6.9.0 RC2 wont boot past "/bzroot...ok", fresh 6.8.3 boots fine
  • Urgent
I've already made two reddit posts (first and second, which led me here), but I guess it's better the create a real bug report. So I've got a "new" used PC and I created a fresh 6.8.3 install usb stick. So 6.8.3 boots fine but if I update to 6.9.0 RC2 on the running unraid or create a new 6.9.0 RC2 stick it won't boot.
I get to the boot menu but after choosing "Unraid OS" or "Unraid OS with Gui" it gets stuck after
/bzimage...ok
/bzroot...ok
 and
/bzimage...ok
/bzroot...ok
/bzroot-gui...ok
I enabled debug mode in syslinux and got another line on startup, so it says:
/bzimage...ok
/bzroot...ok
early console in setup code
PC specs:
  • z170h4-ea
  • Intel Core i7 6700
  • 16GB DDR4 2133
  • GTX 970 (tried it with and without it)
Edit:
As I tested right now: No, 6.9 Stable won't boot either.
