Jump to content
  • [6.12.3] Network Settings -> Interface Extras -> Include listening interfaces doesn't work with OpenVPN
    jesta
    • Minor
    I am running an OpenVPN Docker container (ich777/openvpn-client) with network=host and want my unRAID webUI to be accessible via this VPN.
    I can add the corresponding interface (tun0) to Network Settings -> Interface Extras -> Include listening interfaces but the webUI doesn't bind to the tunnel IP after a restart. I need to delete and readd the entry to get it to work.
    I guess this happens because the VPN container is still starting when the webUI process binds to the ports.
    • Upvote 1
    User Feedback
    Recommended Comments
    Hey, wanted to add my own experience to this as I am having a very simlar problem and don't want to raise a duplicate bug report. I am trying make the unraid web UI accessible to docker containers by including the docker0 interface in the Include Listening Interfaces section, I do this so I can make the web panel accessible externally behind a second layer of auth for protection, as well as automate some other bits and pieces. On reboot, I experience the same issue as OP, I must remove and re-add the interface to the list in order for it to actually apply this setting. A fix for this would be appreciated, if you need any other information just let me know!
    Link to comment
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
