Blaze9 Posted December 29, 2020 Share Posted December 29, 2020 Hy ya'll. I'm getting super slow connections between my MBP/Windows desktops (Desktop is wired, MBP is wireless). Speed tests between server and external network (using speedtest-tracker docker) shows minimum of 850Mbps up and down, so connection between my switch and Unraid is fine. Speed tests between clients (wired) show the same 800/800 connection, and wireless shows around 350-400Mbps up/down so all my connections are not the issue. I'm transferring using SMB shares on both windows and mac. Mounting it with `smb://192.168.99.10` (server's IP). I can access all my shares. I've tried creating a new share on my SSD Cache array and writing to just that from my clients so I skip parity writing. It still doesn't allow for fast transfers. iPerf3 also shows slow transfers, around 5Mbps. All services running on unraid can serve files fast. Plex constantly shows 100Mbps+ connections when I'm streaming a 4k file from Unraid. I can also download at 100MB/s (full gig pipe) when using torrents on qBT on unraid. Running out of options. I use my share to backup my DSLR pics and it's getting quite annoying waiting hours for a single SD card to be backed up... Does anyone have suggestions? Quote Link to comment
Blaze9 Posted February 2, 2021 Author Share Posted February 2, 2021 Bumping this, it's been a while with no replies! Any help appreciated! Sabnzb+, plex, qbt all hit high transfer rates, still only LAN to windows/mac/android file transfers are super slow. Quote Link to comment
